Fehler beim Hochladen
ich habe eie Fehlermeldung beim Hochladen bekommen. Kann mir jemand das erklären?
Roland
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino: In function 'int voiceMenu(int, int, int, bool, int)':
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino:347:62: warning: default argument given for parameter 4 of 'int voiceMenu(int, int, int, bool, int)' [-fpermissive]
               bool preview = false, int previewFromFolder = 0) {
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino:25:5: note: previous specification in 'int voiceMenu(int, int, int, bool, int)' here
 int voiceMenu(int numberOfOptions, int startMessage, int messageOffset,
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino:347:62: warning: default argument given for parameter 5 of 'int voiceMenu(int, int, int, bool, int)' [-fpermissive]
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino: In function 'bool readCard(nfcTagObject*)':
C:\Users\Roland\Downloads\TonUINO-master\TonUINO-master\Tonuino\Tonuino.ino:496:5: warning: return-statement with no value, in function returning 'bool' [-fpermissive]
     return;
In file included from C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:8:0:
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h: In constructor 'MFRC522Extended::MFRC522Extended(uint8_t)':
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:81:44: warning: 'MFRC522::MFRC522(byte)' is deprecated: use MFRC522(byte chipSelectPin, byte resetPowerDownPin) [-Wdeprecated-declarations]
  MFRC522Extended(uint8_t rst) : MFRC522(rst) {};
In file included from C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:10:0,
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.h:339:2: note: declared here
  MFRC522(byte resetPowerDownPin);
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
  if (!MIFARE_OpenUidBackdoor(logErrors)) {
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1709:6: note: declared here
 bool MFRC522::MIFARE_OpenUidBackdoor(bool logErrors) {
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
  MIFARE_OpenUidBackdoor(logErrors);
C:\Users\Roland\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
Der Sketch verwendet 15288 Bytes (49%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 518 Bytes (25%) des dynamischen Speichers, 1530 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
Zitat aus #software FAQ:
Ich bekomme jede Menge Meldungen wenn ich den Sketch kompiliere.
  • Das ist „normal“. Es handelt sich nur um Warnungen und das Programm wird ohne Probleme auf den Arduino übertragen.
Wenn du diese Meldung hier am Ende bekommst ist alles gut:
PS: Du bist schon sehr lange Mitglied, ein Blick in die FAQ hätte ich mir gewünscht.
PPS: Beim einfügen von Code oder Konsolenausgaben, bitte den </> Knopf verwenden!
Blick in die FAQ…trotzdem, Danke.
