Hallo
Kannst mir jemand bestätigen ob es jetzt fünktioniert hat?
Executing task: C:\Users\RUALB.platformio\penv\Scripts\platformio.exe run --target upload --environment TonUINO_Esp32_5f
Warning! Ignore unknown configuration option lib_deps_esp32 in section [env]Processing TonUINO_Esp32_5f (platform: espressif32; board: arduino_nano_esp32; framework: arduino)
Verbose mode can be enabled via -v, --verbose optionCONFIGURATION: https://docs.platformio.org/page/boards/espressif32/arduino_nano_esp32.htmlPLATFORM: Espressif 32 (6.12.0) > Arduino Nano ESP32HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB FlashDEBUG: Current (cmsis-dap) External (cmsis-dap, dfu, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)PACKAGES:
framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
tool-dfuutil-arduino @ 1.11.0
tool-esptoolpy @ 2.40900.250804 (4.9.0)
tool-mkfatfs @ 2.0.1
tool-mklittlefs @ 1.203.210628 (2.3)
tool-mkspiffs @ 2.230.0 (2.30)
toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5LDF: Library Dependency Finder → LDF Modes: Finder ~ chain, Compatibility ~ softFound 41 compatible librariesScanning dependencies…Dependency Graph|-- JC_Button @ 2.1.2|-- MFRC522_fix @ 1.4.12|-- DFPlayer Mini Mp3 by Makuna @ 1.2.3|-- Adafruit NeoPixel @ 1.15.1|-- EspSoftwareSerial @ 8.1.0|-- AsyncTCP @ 3.3.6|-- ESPAsyncWebServer @ 3.7.2|-- ArduinoJson @ 7.3.0|-- SPI @ 2.0.0|-- Update @ 2.0.0|-- EEPROM @ 2.0.0|-- DNSServer @ 2.0.0|-- Preferences @ 2.0.0|-- WiFi @ 2.0.0Building in release modeRetrieving maximum program size .pio\build\TonUINO_Esp32_5f\firmware.elfChecking size .pio\build\TonUINO_Esp32_5f\firmware.elfAdvanced Memory Usage is available via „PlatformIO Home > Project Inspect“RAM: [== ] 24.4% (used 79976 bytes from 327680 bytes)Flash: [===== ] 47.0% (used 1479117 bytes from 3145728 bytes)Configuring upload protocol…AVAILABLE: cmsis-dap, dfu, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpaCURRENT: upload_protocol = dfuUploading .pio\build\TonUINO_Esp32_5f\firmware.bindfu-util 0.11-arduino4
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.Copyright 2010-2021 Tormod Volden and Stefan SchmidtThis program is Free Software and has ABSOLUTELY NO WARRANTYPlease report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device…Device ID 2341:0070Device DFU version 0101Claiming USB DFU Interface…Setting Alternate Interface #0 …Determining device status…DFU state(2) = dfuIDLE, status(0) = No error condition is presentDFU mode device DFU version 0101Device returned transfer size 4096Copying data from PC to DFU device
Download [ ] 0% 0 bytesDownload [ ] 0% 8192 bytesDownload [= ] 4% 61440 bytesDownload [== ] 8% 118784 bytesDownload [=== ] 12% 180224 bytesDownload [=== ] 13% 204800 bytesDownload [==== ] 16% 237568 bytesDownload [==== ] 19% 294912 bytesDownload [===== ] 20% 299008 bytesDownload [====== ] 24% 356352 bytesDownload [====== ] 27% 401408 bytesDownload [======= ] 28% 417792 bytesDownload [======== ] 32% 475136 bytesDownload [======== ] 32% 483328 bytesDownload [========= ] 36% 536576 bytesDownload [========= ] 39% 589824 bytesDownload [========== ] 40% 593920 bytesDownload [=========== ] 44% 655360 bytesDownload [=========== ] 45% 667648 bytesDownload [============ ] 48% 712704 bytesDownload [============= ] 52% 774144 bytesDownload [============== ] 56% 831488 bytesDownload [============== ] 57% 860160 bytesDownload [=============== ] 60% 892928 bytesDownload [=============== ] 63% 946176 bytesDownload [================ ] 64% 950272 bytesDownload [================= ] 68% 1011712 bytesDownload [================= ] 70% 1048576 bytesDownload [================== ] 72% 1069056 bytesDownload [================== ] 75% 1126400 bytesDownload [=================== ] 76% 1130496 bytesDownload [==================== ] 80% 1187840 bytesDownload [==================== ] 82% 1224704 bytesDownload [===================== ] 84% 1249280 bytesDownload [====================== ] 88% 1306624 bytesDownload [====================== ] 88% 1318912 bytesDownload [======================= ] 92% 1368064 bytesDownload [======================= ] 94% 1400832 bytesDownload [======================== ] 96% 1425408 bytesDownload [=========================] 100% 1479536 bytesDownload done.DFU state(7) = dfuMANIFEST, status(0) = No error condition is presentDFU state(2) = dfuIDLE, status(0) = No error condition is presentDone!================================================================ [SUCCESS] Took 31.14 seconds ================================================================
Environment Status Duration
TonUINO_Esp32_5f SUCCESS 00:00:31.143================================================================= 1 succeeded in 00:00:31.143 =================================================================
Terminal will be reused by tasks, press any key to close it.
