Hallo ihr lieben. Ich kann keine Software aufspielen. ERhalte folgende Fehlerhinweise:
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void setup()':
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:758:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
mp3.setEq(mySettings.eq - 1);
In file included from C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1:0:
D:\Users\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:251:10: note: initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
void setEq(DfMp3_Eq eq)
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void adminMenu(bool)':
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1117:37: warning: default argument given for parameter 1 of 'void adminMenu(bool)' [-fpermissive]
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:80:6: note: previous specification in 'void adminMenu(bool)' here
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1192:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1318:22: warning: invalid conversion from 'int8_t* {aka signed char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
if (askCode(pin)) {
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1332:6: note: initializing argument 1 of 'bool askCode(uint8_t*)'
bool askCode(uint8_t *code) {
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:74:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\micha\AppData\Local\Temp\Temp2_TonUINO-DEV.zip\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
Wer kann mir helfen?!
Danke und liebe Grüße
