Sketch hochladen funktioniert nicht
ich konnte leider kein ähnliches Thema finden, zumindest nichts was mir weiterhelfen könnte.
Ich versuche gerade meinen 4. Tonuino zu bauen, bisher klappte das hochladen des Sketches immer (fast) reibungslos. Jetzt versuche ich denselben Sketch ohne Änderung direkt wieder auf den neuen Arduino zu kopieren, was nicht mehr klappt. Folgender Fehler:
Arduino: 1.8.13 (Windows 10), Board: „Arduino Nano, ATmega328P (Old Bootloader)“
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void setup()':
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:758:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
   mp3.setEq(mySettings.eq - 1);
In file included from C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1:0:
C:\Users\Win10\Downloads\arduino-1.8.13-windows\arduino-1.8.13\portable\sketchbook\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:251:10: note:   initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
     void setEq(DfMp3_Eq eq)
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void adminMenu(bool)':
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1117:37: warning: default argument given for parameter 1 of 'void adminMenu(bool)' [-fpermissive]
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:80:6: note: previous specification in 'void adminMenu(bool)' here
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1192:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1318:22: warning: invalid conversion from 'int8_t* {aka signed char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
       if (askCode(pin)) {
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1332:6: note:   initializing argument 1 of 'bool askCode(uint8_t*)'
 bool askCode(uint8_t *code) {
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:74:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Win10\Desktop\Tonuino\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
Der Sketch verwendet 24668 Bytes (80%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x41
Kann mir da jemand weiterhelfen? Danke!
Hast du die Hinweis aus der FAQ schon durch?
Ja, die Vorschläge in der FAQ kann ich abhaken weil ich das ja alles schon 3 mal erfolgreich mit denselben Einstellungen und auch demselben USB-Kabel hochgeladen habe, es müsste also theoretisch wieder funktionieren. Lediglich das USB-Kabel könnte ich mal austauschen, wer weiß ob das nicht plötzlich defekt ist.
Ich habe eher die neue Platine im Verdacht, vielleicht habe ich jetzt ein anderes Modell erwischt und der Treiber passt nicht mehr? Ich bestelle zwar jedesmal über Amazon dasselbe Tonuino-Set aber man weiß ja nicht ob der Händler mittendrin mal das Modell wechselt. Kann das der Grund sein? Leider kann ich die Platine nicht mehr von unten lesen, ich habe sie bereits auf eine Leiterplatte gelötet. Gibt’s ne andere Möglichkeit zu prüfen ob es ein anderes Modell ist?
Das ist von dem Arduino Nano abhängig, den du verwendest. Kann also bei den bisherigen durchaus anders gewesen sein. Also, wenn noch nicht geschehen, auf jeden Fall ausprobieren.
Hey, vielen Dank für die Hilfe! Ich habs grad ausprobiert, tatsächlich war das die Lösung. Schönes Wochenende!
