mhhh die Fehler habe ich bisher ignoriert weil im Forum mehrmals stand die Fehler beim kompillieren seien normal
D:\Tonuino\Tonuino.ino: In function 'void setup()':
D:\Tonuino\Tonuino.ino:420:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
mp3.setEq(mySettings.eq - 1);
In file included from D:\Tonuino\Tonuino.ino:1:0:
C:\Users\Simon\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:193:10: note: initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
void setEq(DfMp3_Eq eq)
D:\Tonuino\Tonuino.ino: In function 'void adminMenu()':
D:\Tonuino\Tonuino.ino:777:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
D:\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
D:\Tonuino\Tonuino.ino:875:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
D:\Tonuino\Tonuino.ino:71:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
D:\Tonuino\Tonuino.ino:875:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
D:\Tonuino\Tonuino.ino:875:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
D:\Tonuino\Tonuino.ino:875:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Simon\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h: In instantiation of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::sendPacket(uint8_t, uint16_t, uint16_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char; uint16_t = unsigned int]':
C:\Users\Simon\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:112:19: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::playFolderTrack(uint8_t, uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char]'
D:\Tonuino\Tonuino.ino:210:57: required from here
C:\Users\Simon\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:306:114: warning: narrowing conversion of '(arg >> 8)' from 'uint16_t {aka unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
uint8_t out[DfMp3_Packet_SIZE] = { 0x7E, 0xFF, 06, command, 00, (arg >> 8), (arg & 0x00ff), 00, 00, 0xEF };
C:\Users\Simon\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:306:114: warning: narrowing conversion of '(arg & 255u)' from 'uint16_t {aka unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
In file included from C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:8:0:
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h: In constructor 'MFRC522Extended::MFRC522Extended(uint8_t)':
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:81:44: warning: 'MFRC522::MFRC522(byte)' is deprecated: use MFRC522(byte chipSelectPin, byte resetPowerDownPin) [-Wdeprecated-declarations]
MFRC522Extended(uint8_t rst) : MFRC522(rst) {};
In file included from C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:10:0,
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.h:337:2: note: declared here
MFRC522(byte resetPowerDownPin);
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
if (!MIFARE_OpenUidBackdoor(logErrors)) {
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1709:6: note: declared here
bool MFRC522::MIFARE_OpenUidBackdoor(bool logErrors) {
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
MIFARE_OpenUidBackdoor(logErrors);
C:\Users\Simon\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
Der Sketch verwendet 19800 Bytes (64%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 800 Bytes (39%) des dynamischen Speichers, 1248 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
