Habe gerade meinen ersten TonUnin zusammengebaut.
Ardunio in der Version 1.8.12 heruntergeladen und installiert.
Die 3 extra Bibiotheken installiert in neuester Version
MFRC522
DFPlayer Mini Mp3 by Makuna
JC_Button
die TonUINO-DEV heruntergeladen , entpackt und mit ardunio geladen.
Beim hochladen bekomme ich diese Fehler angezeigt
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void setup()':
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:753:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
mp3.setEq(mySettings.eq - 1);
In file included from C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1:0:
C:\Users\Aldi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:245:10: note: initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
void setEq(DfMp3_Eq eq)
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void adminMenu(bool)':
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1112:37: warning: default argument given for parameter 1 of 'void adminMenu(bool)' [-fpermissive]
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:80:6: note: previous specification in 'void adminMenu(bool)' here
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1187:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1313:22: warning: invalid conversion from 'int8_t* {aka signed char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
if (askCode(pin)) {
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1327:6: note: initializing argument 1 of 'bool askCode(uint8_t*)'
bool askCode(uint8_t *code) {
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1344:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:74:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1344:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1344:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Aldi\Downloads\ardunio treiber\TonUINO-DEV1\TonUINO-DEV\Tonuino\Tonuino.ino:1344:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
Der Sketch verwendet 24632 Bytes (80%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
und im Admin Menue habe ich keinen Ton nur einen Error auf der Console
_____ _____ _____ _____ _____
|_ _|___ ___| | | | | | |
TonUINO Version 2.1
=== loadSettingsFromFlash()
Version: 2
Maximal Volume: 25
Minimal Volume: 5
Initial Volume: 15
EQ: 1
Locked: 0
Sleep Timer: 0
Inverted Volume Buttons: 1
Admin Menu locked: 0
Admin Menu Pin: 1111
=== setstandbyTimer()
0
Firmware Version: 0x92 = v2.0
=== playShortCut()
3
Shortcut not configured!
=== volumeUp()
16
=== volumeUp()
17
=== volumeUp()
18
=== volumeUp()
19
=== volumeUp()
20
=== volumeUp()
21
=== volumeUp()
22
=== volumeUp()
23
=== volumeUp()
24
=== volumeUp()
25
=== volumeUp()
25
=== volumeUp()
25
=== disablestandby()
=== adminMenu()
=== voiceMenu() (12 Options)
Com Error 6
1
Com Error 6
2
Com Error 6
3
4
Com Error 6
Hoffe mir kann einer weiterhelfen
Viele Grüße Matthias
