ich bin neu in der Community und baue gerade meinen ersten Tonuino.
Um alles einmal zu testen nutze ich Jumper Wire und verzichte vorab auf Löten.
Leider habe ich einige Probleme und bekomme den Tonuino nicht zum Laufen:
Problem 1. Beim Kompillieren bekomme ich einige Fehlermeldungen:
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void setup()':
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:758:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
mp3.setEq(mySettings.eq - 1);
In file included from C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1:0:
C:\Users\Admin\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:251:10: note: initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
void setEq(DfMp3_Eq eq)
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void adminMenu(bool)':
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1117:37: warning: default argument given for parameter 1 of 'void adminMenu(bool)' [-fpermissive]
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:80:6: note: previous specification in 'void adminMenu(bool)' here
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1192:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1318:22: warning: invalid conversion from 'int8_t* {aka signed char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
if (askCode(pin)) {
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1332:6: note: initializing argument 1 of 'bool askCode(uint8_t*)'
bool askCode(uint8_t *code) {
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:74:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Admin\Documents\Tonuino Projekt\TonUINO-DEV\Tonuino\Tonuino.ino:1349:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
Der Sketch verwendet 24668 Bytes (80%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Problem 2:
Die Konsole sagt der RFID Leser funktioniert nicht.
Hinweis: die rote LED läuchtet jedoch
_____ _____ _____ _____ _____
|_ _|___ ___| | | | | | |
TonUINO Version 2.1
=== loadSettingsFromFlash()
Version: 2
Maximal Volume: 25
Minimal Volume: 5
Initial Volume: 15
EQ: 1
Locked: 0
Sleep Timer: 0
Inverted Volume Buttons: 1
Admin Menu locked: 0
Admin Menu Pin: 1111
=== setstandbyTimer()
0
Firmware Version: 0xFF = (unknown)
=== playShortCut()
3
Shortcut not configured!
Problem 3: Die Play Taste wird nicht erkannt. Volume up und - down wird jedoch in der Konsole angezeigt.
Hinweis: ich habe die Taster/Knöpfe ausgetauscht, ohne Erfolg.
Hat jemand eine Idee woran das liegen könnte?
Evtl. hängen die Probleme miteinander zusammen.
Ich habe meinen Aufbau bereits mit mehreren neuen Arduinos und RFID Leser ohne Erfolg probiert…
Vielen Dank vorab und viele Grüße!
Tozitobsen
