Hallo mal wieder
Ich baue zur Zeit den 5. Tonuino habe aber zwischenzeitlich den Rechner ersetzen müssen und nun habe ich hier die Arduino IDE in Version 1.8.8 installiert (lag hier noch auf dem NAS) den Treiber CH341SER und die benötigten Bibliothekten.
Tonuino Sketch eingebunden und hochladen gedrückt…
dann kommt folgende Fehlermeldung: Was sagt mir das?
Arduino: 1.8.8 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void setup()':
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:420:27: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
mp3.setEq(mySettings.eq - 1);
In file included from \\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:1:0:
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:202:10: note: initializing argument 1 of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setEq(DfMp3_Eq) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
void setEq(DfMp3_Eq eq)
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'void adminMenu()':
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:779:29: warning: invalid conversion from 'int' to 'DfMp3_Eq' [-fpermissive]
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino: In function 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)':
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:877:120: warning: default argument given for parameter 4 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:71:9: note: previous specification in 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' here
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:877:120: warning: default argument given for parameter 5 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:877:120: warning: default argument given for parameter 6 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:877:120: warning: default argument given for parameter 7 of 'uint8_t voiceMenu(int, int, int, bool, int, int, bool)' [-fpermissive]
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h: In instantiation of 'uint16_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::listenForReply(uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint16_t = unsigned int; uint8_t = unsigned char]':
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:98:27: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::loop() [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
\\DISKSTATION\Zeug\Arduino\TonUINO-DEV2.1\TonUINO-DEV\Tonuino\Tonuino.ino:383:14: required from here
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:439:63: error: 'OnUsbOnline' is not a member of 'Mp3Notify'
T_NOTIFICATION_METHOD::OnUsbOnline(replyArg);
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:450:65: error: 'OnUsbInserted' is not a member of 'Mp3Notify'
T_NOTIFICATION_METHOD::OnUsbInserted(replyArg);
C:\Users\Fischi\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:461:64: error: 'OnUsbRemoved' is not a member of 'Mp3Notify'
T_NOTIFICATION_METHOD::OnUsbRemoved(replyArg);
