ich habe früher unter Windows keine Probleme gehabt. Bin jetzt auf einem LinuxPC, und kann auf einmal nicht mehr kompilieren.
→ Aktuelle TNG Version aus dem Git
→ Die Bibilotheken aus der Readme mit dem Bibilothekverwalter heruntergeladen
→ constants.hpp editiert für classic und 3button
→ platform.local in den angegebenen Ordner verschoben
Jetzt bekomme ich diese Meldung
>In file included from /home/nicole/Downloads/TonUINO-TNG/TonUINO-TNG.ino:1:0:
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipOriginal.h:30:1: error: expected class-name before '{' token
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipOriginal.h:34:13: error: 'Mp3_Packet_WithCheckSum' does not name a type
typedef Mp3_Packet_WithCheckSum SendPacket;
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipOriginal.h:35:13: error: 'Mp3_Packet_WithCheckSum' does not name a type
typedef Mp3_Packet_WithCheckSum ReceptionPacket;
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipOriginal.h:37:18: error: 'SendPacket' does not name a type
static const SendPacket generatePacket(uint8_t command, uint16_t arg, bool requestAck = false)
In file included from /home/nicole/Downloads/TonUINO-TNG/TonUINO-TNG.ino:2:0:
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:33:40: error: 'Mp3_Packet_WithCheckSum' does not name a type
static uint16_t calcChecksum(const Mp3_Packet_WithCheckSum& packet)
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:44:29: error: 'Mp3_Packet_WithCheckSum' has not been declared
static void setChecksum(Mp3_Packet_WithCheckSum* out)
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:52:40: error: 'Mp3_Packet_WithCheckSum' does not name a type
static bool validateChecksum(const Mp3_Packet_WithCheckSum& in)
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h: In static member function 'static uint16_t Mp3ChipBase::calcChecksum(const int&)':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:36:51: error: request for member 'version' in 'packet', which is of non-class type 'const int'
for (const uint8_t* packetByte = &(packet.version); packetByte != &(packet.hiByteCheckSum); packetByte++)
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:36:84: error: request for member 'hiByteCheckSum' in 'packet', which is of non-class type 'const int'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h: In static member function 'static void Mp3ChipBase::setChecksum(int*)':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:48:14: error: request for member 'hiByteCheckSum' in '* out', which is of non-class type 'int'
out->hiByteCheckSum = (sum >> 8);
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:49:14: error: request for member 'lowByteCheckSum' in '* out', which is of non-class type 'int'
out->lowByteCheckSum = (sum & 0xff);
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h: In static member function 'static bool Mp3ChipBase::validateChecksum(const int&)':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:55:51: error: request for member 'hiByteCheckSum' in 'in', which is of non-class type 'const int'
return (sum == ((static_cast<uint16_t>(in.hiByteCheckSum) << 8) | in.lowByteCheckSum));
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipBase.h:55:78: error: request for member 'lowByteCheckSum' in 'in', which is of non-class type 'const int'
In file included from /home/nicole/Downloads/TonUINO-TNG/TonUINO-TNG.ino:3:0:
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h: At global scope:
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h:34:13: error: 'Mp3_Packet_WithCheckSum' does not name a type
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h:35:13: error: 'Mp3_Packet_WithCheckSum' does not name a type
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h:37:18: error: 'SendPacket' does not name a type
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h: In static member function 'static bool Mp3ChipIncongruousNoAck::commandSupportsAck(uint8_t)':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/Mp3ChipIncongruousNoAck.h:56:27: error: 'Mp3_Commands_Requests' was not declared in this scope
return (command > Mp3_Commands_Requests);
In file included from /home/nicole/Downloads/TonUINO-TNG/TonUINO-TNG.ino:5:0:
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h: In instantiation of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::sendPacket(uint8_t, uint16_t, bool) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char; uint16_t = unsigned int]':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:561:27: required from 'DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::reply_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::retryCommand(uint8_t, uint8_t, uint16_t, bool) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char; uint16_t = unsigned int]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:599:21: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::setCommand(uint8_t, uint16_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char; uint16_t = unsigned int]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:270:19: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::start() [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000]'
/home/nicole/Downloads/TonUINO-TNG/src/mp3.hpp:218:56: required from here
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:458:45: error: no type named 'SendPacket' in 'class Mp3ChipIncongruousNoAck'
typename T_CHIP_VARIANT::SendPacket packet = T_CHIP_VARIANT::generatePacket(command, arg, requestAck);
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h: In instantiation of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::loop() [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000]':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:453:13: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::drainResponses() [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:547:27: required from 'DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::reply_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::retryCommand(uint8_t, uint8_t, uint16_t, bool) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char; uint16_t = unsigned int]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:76:59: error: no type named 'ReceptionPacket' in 'class Mp3ChipIncongruousNoAck'
_serial.available() >= static_cast<int>(sizeof(typename T_CHIP_VARIANT::ReceptionPacket)))
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h: In instantiation of 'bool DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::readPacket(DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::reply_t*) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000]':
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:606:26: required from 'DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::reply_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::listenForReply(uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:562:39: required from 'DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::reply_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD, T_CHIP_VARIANT, C_ACK_TIMEOUT>::retryCommand(uint8_t, uint8_t, uint16_t, bool) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; T_CHIP_VARIANT = Mp3ChipIncongruousNoAck; long unsigned int C_ACK_TIMEOUT = 4000; uint8_t = unsigned char; uint16_t = unsigned int]'
/home/nicole/Arduino/libraries/DFPlayer_Mini_Mp3_by_Makuna/src/DFMiniMp3.h:471:50: error: no type named 'ReceptionPacket' in 'class Mp3ChipIncongruousNoAck'
typename T_CHIP_VARIANT::ReceptionPacket in;
Kann mir jemand helfen? Ich mache bestimmt etwas ganz dummes falsch…
