Höre nur ein Pips
Hallo
Neuer TonUINO gemacht
Höre nur ein Pieps beim Start (dann nichts mehr)
Hier das Log
Not connected to WiFi NETGEAR14, starting AP TonUINO
AP IP address: 192.168.4.1
MFRC522:0
com to mfrc broken
Volume: 15
track_count: 242
isPlaying: 0
isPlaying: 0
Track end: 34
Bitte um Hilfe
Hier noch das Web Log
Connected to ws://192.168.4.1:/ws_serial
[000 01.206]
[000 01.206]  _____         _____ _____ _____ _____
[000 01.206] |_   _|___ ___|  |  |     |   | |     |
[000 01.206]   | | | . |   |  |  |-   -| | | |  |  |
[000 01.206]   |_| |___|_|_|_____|_____|_|___|_____|
[000 01.206] TonUINO Version 3.x - refactored by Boerge1
[000 01.206]
[000 01.207] created by Thorsten Voß and licensed under GNU/GPL.
[000 01.207] Information and contribution at https://tonuino.de.
[000 01.207]
[000 01.207] V3.3.1 12.10.25
[000 01.207] ESP32 Nano 5
[000 01.497] EEPROM begin: 1
[000 01.497] Ver:2
[000 01.497] Vol:25 5 15 25 5 15
[000 01.498] EQ:3
[000 01.498] ST:0
[000 01.498] IB:1
[000 01.498] AL:0
[000 01.498] AP:1111
[000 01.498] PCR:0
[000 01.503] wifi settings - ssid: NETGEAR14, hostname: tonuino Paps, st_ip: 0, st_ip_address: 0.0.0.0, st_ip_gw: 0.0.0.0, st_ip_subnet: 0.0.0.0, st_ip_dns1: 0.0.0.0, st_ip_dns2: 0.0.0.0
[000 01.564] Connecting to WiFi NETGEAR14 ...
[000 11.564] Not connected to WiFi NETGEAR14, starting AP TonUINO
[000 12.074] AP IP address: 192.168.4.1
[000 12.227] MFRC522:0
[000 12.227] com to mfrc broken
[000 13.051] Volume: 15
[000 13.474] track_count: 242
[000 14.475] enter Idle
[000 14.475] btn/cmd: start/start
[000 14.476] enqueue mp3 262 0
[000 14.476] play mp3 262
[000 15.423] isPlaying: 1
[000 15.473] isPlaying: 0
[000 15.723] isPlaying: 1
[000 15.973] isPlaying: 0
[000 16.023] Track end: 34
[013 01.607] websocket [1] Connected!
[013 15.612] websocket [1] Disconnected!
Connected
Hallo Ruedi,
Du baust ja sehr eifrig
Damit läuft der TonUINO eigentlich schon richtig, zumindest mal die Software und die Kommunikation mit dem DF-Player
Das Log zeigt eindeutig, dass der Kartenleser nicht erkannt wird oder nicht funktioniert. Damit ist klar, dass bei Auflegen einer Karte keine Reaktion erfolgen kann.
Abhilfe:
Anschlüsse von MFRC zu Arduino peinlich genau überprüfen, auch die Lötstellen.
Reinigung der Lötstellen von möglichen Rückständen und Verunreinigungen.
Ist das wirklich so ?
Da der TonUINO ansonsten zu laufen scheint, wären noch ein paar weitere Angaben hilfreich.
Gibt es keine Reaktion auf Tastendrücke, die im Log angezeigt werden?
Ich vermute, dass das auch noch funktionieren wird.
Du hast das Webinterface aufgerufen und müsstest von dort eigentlich eine Wiedergabe starten können, ohne dass der Kartenleser benötigt wird.
Ersatzweise könnte man auch über das Admin-Menü einen Shortcut programmieren
Ok Danke
(Sehr eifrig)! Mit vier Enkel😉
Werde am Mo schauen, heute und morgen bei den Enkeln am sitzen😃
