Ich bekomme immer ein Fehler beim Übertragen der Software.
Was jemand was das sein könnte?`
Liebe Grüße Kai
Arduino: 1.8.7 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
D:\Desktop\Tonuino\Tonuino.ino: In function 'int voiceMenu(int, int, int, bool, int)':
D:\Desktop\Tonuino\Tonuino.ino:337:62: warning: default argument given for parameter 4 of 'int voiceMenu(int, int, int, bool, int)' [-fpermissive]
bool preview = false, int previewFromFolder = 0) {
D:\Desktop\Tonuino\Tonuino.ino:25:5: note: previous specification in 'int voiceMenu(int, int, int, bool, int)' here
int voiceMenu(int numberOfOptions, int startMessage, int messageOffset,
D:\Desktop\Tonuino\Tonuino.ino:337:62: warning: default argument given for parameter 5 of 'int voiceMenu(int, int, int, bool, int)' [-fpermissive]
D:\Desktop\Tonuino\Tonuino.ino: In function 'bool readCard(nfcTagObject*)':
D:\Desktop\Tonuino\Tonuino.ino:486:5: warning: return-statement with no value, in function returning 'bool' [-fpermissive]
return;
In file included from D:\Desktop\Tonuino\Tonuino.ino:1:0:
D:\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h: In instantiation of 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::sendPacket(uint8_t, uint16_t, uint16_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char; uint16_t = unsigned int]':
D:\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:112:19: required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::playFolderTrack(uint8_t, uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char]'
D:\Desktop\Tonuino\Tonuino.ino:80:54: required from here
D:\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:300:114: warning: narrowing conversion of '(arg >> 8)' from 'uint16_t {aka unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
uint8_t out[DfMp3_Packet_SIZE] = { 0x7E, 0xFF, 06, command, 00, (arg >> 8), (arg & 0x00ff), 00, 00, 0xEF };
D:\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:300:114: warning: narrowing conversion of '(arg & 255u)' from 'uint16_t {aka unsigned int}' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
In file included from D:\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:8:0:
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h: In constructor 'MFRC522Extended::MFRC522Extended(uint8_t)':
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:81:44: warning: 'MFRC522::MFRC522(byte)' is deprecated: use MFRC522(byte chipSelectPin, byte resetPowerDownPin) [-Wdeprecated-declarations]
MFRC522Extended(uint8_t rst) : MFRC522(rst) {};
In file included from D:\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:10:0,
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.h:337:2: note: declared here
MFRC522(byte resetPowerDownPin);
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
if (!MIFARE_OpenUidBackdoor(logErrors)) {
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1709:6: note: declared here
bool MFRC522::MIFARE_OpenUidBackdoor(bool logErrors) {
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1853:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
MIFARE_OpenUidBackdoor(logErrors);
D:\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1882:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
Der Sketch verwendet 15196 Bytes (49%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 518 Bytes (25%) des dynamischen Speichers, 1530 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x27
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x27
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x27
