English Language Files for Classic?
I’m looking for the English language files for the classic. I’ve found there is a deprecated dev version, but can’t find anything current for the classic version. Thank you in advance.
You can find the english (Text) files for download in GitHub where the program Code is.
Conversion to mp3 files may need some effort using a tts site like https://ttsmp3.com/.
As far as I know, there are no ready-to-use mp3 files available for latest program versions.
If No mp3 Download ist available from the Site you can use audacity for recording the Output of your soundcard as described Here: Mitschnitt der Soundkarten-Ausgabe
Hope this helps and your time and skills allow to make it.
So I need to create English audio files for the menus? Okay. Thanks.
Meanwhile I could manage to create english audio files which are available for Downlod now.
For more information and help you can refer to TonUINO Kompendium, written in german language but well acceptabe translation are available by help of DeepL
Thanks, I’m about halfway through just recording them. I might as well put my voice on my kid’s player right?
Shall I integrate this into the software on github. Under which license were the files generated?
Die Dateien habe ich mit freiem online TTS generiert.
Kannst Du gerne bei github integrieren, dort gehören sie dann ja eigentlich auch hin.
Dann nehme ich sie von meinem Server runter, nachdem Du hier einen Link auf github eingestellt hast
Now the English sd-card is integrated into the official TonUINO software and you can download it from github: sd-card-englisch
