What do you expect the TonUNIO to do? Everything that appears in the Serial Monitor is normal. What happens when you place a card on the rfid reader? What happens when you press all 3 button for more than one second?
There IS a resistor coming off of the TX pin on the DFplayer. It’s 1K. I just used heat shrink tubing so it looks like a normal wire with some bumps.
but now I am getting com error 6 and it is super odd. I’m reading the Com error 6 post but I have to admit I am not understanding much.
By chance my mp3 and advert folders are causing the issue, do you have the correct English version? I found one somewhere but now I question if I did something wrong. But german speaking does not help me, lol.
Just try out the original german files - even if you dont understand anything. Com 6 error means „file not found“.
What does the content of the folder on the SD card look like?
Based on the console output, this is not what you are doing. The console output of my fork looks completely different. You are using the original DEV, which only works with the original mp3 and advert files. The firmware always has to match the files.
If you use my english mp3 and advert folders you also have to use my firmware fork.
Ok I have corrected that. I got the firmware from the right folder. When I clicked the project and went to the master folder It somehow kept bringing me to the original project. Maybe a favorites or bookmark error on my end.
I have also found my computer does not appear to be strong enough to handle the device. I have a battery pack and am able to get it to speak using that.
Now the buttons aren’t really doing anything but I get to „Lets Go!“
and
„A new card was found…“
Corrected the file names to .001, etc.
However my buttons don’t work the way they are supposed to. I can get the first song to play. Then it gets stuck.
my apologies. I was using the wrong files. I’ve always done everything from scratch on the arduino (simple robotics) using the built in sample code. Most of my projects had lines in the hundreds, not thousands, so a grab and go file system is new to me and a bit intimidating.
Exciting stuff. Busy was all set. The extra power from the battery pack seems to really make a difference. I got the buttons to respond. I was able to program one card.
For some reason in my folder 01 it dosn’t see songs 002, 003, 004
But it will read folder 02 song 001. (I added it after I had song 001 on a card). It acts like it’s going to add song Folder 02/001 but then it gives me an error.
