TonUINO Version 2.1
Fork by Marco Schulz
load settings from flash
Version: 2
Max Vol: 25
Min Vole: 2
Init Vol: 15
EQ: 1
Locked: 0
Sleep Timer: 0
Inverted Vol Buttons: 1
Admin Menu locked: 0
Admin Menu Pin: 1111
Saved Modifier Mode: 0
set standby timer
milis: 0
Firmware Version: 0x12 = counterfeit chip
=== mfrc522-> RxGain_avg ===
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Shortcut: 1
not configured
Habe eine Modifikationskarte mit Admin Menü dran gehalten, das ist die Ausgabe:
Version: 2
Max Vol: 25
Min Vole: 2
Init Vol: 15
EQ: 1
Locked: 0
Sleep Timer: 0
set standby timer
milis: 0
ReadCardSerial finished
Card UID
AA E7 DD 58
PICC type MIFARE 1KB
Reading data block4...
Data on Card : 13 37 B3 47 02 00 00 01 00 00 00 00 00 00 00 00
set modifier: 0
disable standby timer
adminMenu
voiceMenu 14 Options
1
Ich komme zwar ins Menü, kann durch die Menüpunkte zwar durchschalten, aber nicht bestätigen oder abbrechen. Als ob der Pause/Play Button ohne Funktion ist.
Ohne die Verbindung zum PC geht das Admin Menü über die Modifikationskarte an und ich kann es ganz normal steuern und auch abbrechen. Seltsam. Das Menü geht über die Buttonkombi aber nicht an. Hmm.
Es muss am Button liegen. Ist er richtig angeschlossen? Öffner/Schließer?
Ist auf jeden Fall Daueraktiv. Also Hardware (oder hast du an der Software was geändert bei den Eingängen für die Buttons?).
Ich hab dann noch die Standardwerte für die Lautstärke direkt in der Firmware angepasst und die Zeit für PUSH_ON_OFF über den Play Button auf 5 Sekunden gesetzt. Mehr hab ich nicht gemacht.
@marco-117 Hab die neueste Version getestet. Das Admin Menü läuft nun einwandfrei. Allerding ist da wohl noch ein Wurm drin bei der nextTrack Methode. Diese scheint nicht richtig den nächsten Titel zu schalten. Hier die Ausgabe bei Druck auf nächsten Track (drei mal gedrückt):
TonUINO Version 2.1
Version: 2
Max Vol: 30
Min Vole: 2
Init Vol: 15
EQ: 1
Locked: 0
Sleep Timer: 5
Inverted Vol Buttons: 0
set standby timer
milis: 302136
Card UID
F0 94 D0 59
Data on Card : 13 37 B3 47 02 02 05 00 00 00 00 00 00 00 00 00
2
2
new card
playFolder
30 tracks in folder 2
Audio Book
read memory No. 0 of folder No. 2
play track: 9
write track No. 10 of folder No. 2 in memory No. 0
set standby timer
milis: 311426
write track No. 11 of folder No. 2 in memory No. 0
set standby timer
milis: 317249
write track No. 12 of folder No. 2 in memory No. 0
set standby timer
milis: 319463
Der DFPlayer leuchtet zwar blau, zu hören ist aber nichts. Die Karte muss erstmal entfernt werden und wieder aufgelegt werden, dann ist wieder was zu hören. Danach gibt es gar keine Reaktion bei Druck der Next Taste. Der vorherige Track wird normal geschaltet.
Das weiterspringen läuft jetzt, leider nur solange die Karte drauf bleibt. Nimmt man die Karte einmal weg und legt Sie wieder auf, kann man wieder nicht weiterspringen. Zurück zum vorherigen Track geht aber immer.
