Hi zusammen,
ich habe seit neustem das Problem das das Script von marco79 einen Fehler rausschmeißt:
rsync: recv_generator: failed to stat „/Volumes/SD/42/001.mp3“: Input/output error (5)
rsync: recv_generator: failed to stat „/Volumes/SD/42/002.mp3“: Input/output error (5)
rsync: recv_generator: failed to stat „/Volumes/SD/44/001.mp3“: Input/output error (5)
rsync: recv_generator: failed to stat „/Volumes/SD/44/002.mp3“: Input/output error (5)
rsync: recv_generator: failed to stat „/Volumes/SD/44/003.mp3“: Input/output error (5)
rsync: recv_generator: failed to stat „/Volumes/SD/44/004.mp3“: Input/output error (5)
rsync error: some files could not be transferred (code 23) at /BuildRoot/Library/Caches/com.apple.xbs/Sources/rsync/rsync-52.200.1/rsync/main.c(996) [sender=2.6.9]
oder
rsync: writefd_unbuffered failed to write 32768 bytes [sender]: Broken pipe (32)
rsync: write failed on „/Volumes/SD/01/004.mp3“: Input/output error (5)
rsync error: error in file IO (code 11) at /BuildRoot/Library/Caches/com.apple.xbs/Sources/rsync/rsync-52.200.1/rsync/receiver.c(268) [receiver=2.6.9]
rsync: connection unexpectedly closed (102 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at /BuildRoot/Library/Caches/com.apple.xbs/Sources/rsync/rsync-52.200.1/rsync/io.c(453) [sender=2.6.9]
Ich habe hier 3 SD Karten in Gebrauch. Bei allen das gleiche. Manchmal variert der Fehler bei den Ordnernnummern. Wenn ich die Ordner leer lasse hängt es sich an was anderem auf.
Hat einer eine Idee woran das liegen kann?
